Old 24th January 2010, 09:07 AM
I could be wrong, But I think the drive shafts are slightly different lenghts. And I guess the chassis is designed to offset the diff. If you mirrored then the diff would be offset the wrong way..
If you then offset the diff corectly then the tunnel would be off..
Does that sound plausible?
