Old 24th January 2010, 04:53 PM
niallyc niallyc is offline
Originally Posted by Aussie Haynes View Post
G'Day Dan,
The SR18DET is a really sweet little motor, and can be made to produce a lot of power over Std. Having driven a couple of SR20DET engined Clubmans the poewer delivery is out of this world, it just keeps coming!
The Sr18 is lighter than the SR20 as well, = lighter steering, although some of the models had the inlet going over the rocker cover which raised the height considerably, I'm sure you would find a way round that without breaking the bank.
Regards,
Mike.
Correct on that last point about the inlet but that was only becasue it used a wing moonted intercooler. If you use a front mounted intercooler this is not a problem.
