Old 28th January 2010, 07:24 PM
mark mark is offline
as you know i,m not into electrickery stuff
but i have a spare sierra binnicle AND a standalone rev counter if you want to try them , to make sure everything is working once you sort out the pin as per TT,s post above.
Cheers Ash/Andy
Sounds like i have the only edis connector in the country without the output for the rev counter!
I will try and modify the connector so i can try it and if that fails i may boorow your stuff just to eliminate a dodgy rev counter in my cluster, it did work when i stripped the car but its been stored for almost a year now.
