Old 30th January 2010, 05:39 PM
gingea1pom's Avatar
As was stated it was just tight on the top through bolt mount.
I had two jacks in place and kept lowering them to give a gap of 20mm then pry the diff down in anticipation of it all letting go and ending up on the floor.
Nothing of the sort happened; it was all an anticlimax as the diff is not as heavy as I thought. Once it was free from the mount and resting on the two jacks I just lifted it out from under the car.
It is now sitting up the back of the garage positioned it a comedic way behind the gearbox.
Thanks again the advise was more than useful, as it gave me the confidence to apply some brute force.
Build Pictures
Old 30th January 2010, 05:54 PM
bout 26kg from memory.
Old 30th January 2010, 09:43 PM
Glad you got it sorted Ginge
Sometimes when things are held solid with corrosion you do begin to wonder if it's being held on by a secret fixing
Mind you it wouldn't be the first time I have been beating hell out of something & it was being held by a hidden fixing !!??
Old 30th January 2010, 09:46 PM
gingea1pom's Avatar
Ronnie,
That is exactly what I was worried about, it being still held in by a fixing, all sorted now though.
Cheers Ginge
Build Pictures
Old 30th January 2010, 10:46 PM
Davey's Avatar
Davey Davey is offline
Yup, hands up all those who have got an engine halfway out only to find a throttle cable, choke cable (yes I am that old ) or earth cable was still connected.
D.
Old 30th January 2010, 10:59 PM
gingea1pom's Avatar
Davey,
Earth wire still connected for me sir.
Build Pictures
Old 31st January 2010, 08:15 AM
Davey's Avatar
Over the many years I've been pulling lumps out of cars, vans, trucks etc I think I must have missed disconnecting just about every option at some point.
Earth cables:lots of times, choke cables: yup forgot a few of them too, even a throttle cable on an Austin Allegro I seem to recall but I think my coup de grace must have been when I removed engine and box from a 6 month old MGB to discover I'd forgotten to disconnect the speedo cable, I thought it put up a bit of a fight!
D.
