Old 30th January 2010, 06:35 PM
download cone layout from here http://www.pulserate.com/
make a cone template the size of the exhaust pipe one end and the size of the 4 pipes the other end.
transfer the pattern on to the sheet metal. beat it round using a mallet with something solid underneath. once its round in the shape of a cone tack it to the 4 outlets then use a bolster chisel to shape it into the dips between each pipe then finally weld on the single outlet pipe.
dont forget to weld between the 4 outlet pipes before fitting the cone or the gasses will come out the middle between the pipes.
hope this helps its very hard to explain. but quite easy to show someone. i will see if i can find a video if how to do it after dinner.
Old 30th January 2010, 06:47 PM
Failing that you could just buy one for £78 off ebay.
Old 30th January 2010, 06:51 PM
Tatey's Avatar
Tatey Tatey is offline
I've had a quick look on ebay, what about 2, 2 into 1 collectors followed by 1, 2 into 1 collector, this picture explains it much better:
http://cgi.ebay.co.uk/LOCOST-VINDICA...t _1096wt_939
Im guessing this will use AshG's method, but im not sure if it will be easier to fabricate than a 4 into 1 collector.
Old 30th January 2010, 07:02 PM
dogwood's Avatar
dogwood dogwood is offline
This is how I made mine.
Using a piece of 2" tube.
I slotted it down 4 sides, about 4".
Then I spread it apart till it fitted the 4 pipes.
I then cut out 4 wedge shapes to fill the gap.
Then just fettled and welded it into place.
As Ash says though, don't forget to weld between the 4 pipes
before you fit them
David.
Old 30th January 2010, 07:08 PM
here is another way to do it.
http://www.youtube.com/watch?v=J7oC44v4fy8
Old 30th January 2010, 07:37 PM
Johnnybizzle Johnnybizzle is offline
Thanks for the help guys will tackle a paper template tomorrow and beat the hell out of it, good job ive got plenty of sheet this may take more than one attempt
Cheerz
