Old 10th February 2010, 08:46 PM
Tilly819 Tilly819 is offline
chears iv just seen it in the bible as well, should look first ask later.....
tilly
Old 10th February 2010, 08:54 PM
I got the bible printed today... It's all straight forward untill they start mentioing things about cones domes "ARG" ....
Old 10th February 2010, 09:41 PM
450 front 450 back 900 gross put Na in the other 2.
body type is sports.
to get the kw times the bhp by 0.74570000 it will be lower than the bhp fig.
remember these are nothing to do with the actual weight of the car they are the maximum weight each axle can take and the total weight the whole car can carry including its self, passengers and luggage.
you will only come a cropper if the car weighs more than the weights on the form.
Old 10th February 2010, 10:14 PM
If you have a local frienly MOT station with an ATL it will give you the axle weights on the brake tester and as said the axle weights add up to the DGW
design gross weight ie total weight of vehicle in its heaviest form,fuel/oil/driver/passenger.
Old 10th February 2010, 10:47 PM
when speaking to vosa on the phone they said the gross weight cannot be higher than the combination of the two axle weights but it can can be lower.
Old 17th February 2010, 08:03 AM
drury318 drury318 is offline
I am also filling in IVA forms, what did you put in for max design road speed, 120mph??
Dennis.
Old 17th February 2010, 08:33 AM
Hi Dennis,
Best to keep the design speed as low as you can, only really effects the tyre rating and some design issues, but if you have used sierra engine with standard box and diff then the max speed will be 120mph.
Good Luck.....Andy
Great to see another 2 going into the IVA whirpool.....
