| View Poll Results: What would be your prefered fueling system. | |||
| Stock Carb |
	1 | 3.23% |
| Bike Carb |
	13 | 41.94% |
| After Market Carbs ( Twin 40's Etc ) |
	2 | 6.45% |
| Stock Mechanical Injection |
	1 | 3.23% |
| Stock Electronic Injection |
	6 | 19.35% |
| 3rd Party Injection |
	8 | 25.81% |
| Voters: 31. You may not vote on this poll | |||
	Thread Tools | Display Modes |
			 Right, as the Megasquirt manual puts it, the throttle pedal is the map selector.
	Albert Haynes Roadster FAQ | Haynes Builder Locations Gallery, build thread in Lithuanian / via Google Translate.  |
			 Carbs must disappear like the rotary dial phones and cassette players did. There is much better tech for the same purpose, we're 1/10 the way through the 21-st century!
	You only get a woosh with a dump valve Build Thread Man Cave Mantiques Cecil Street Auto Repairs Garage Carlisle Build Cost £4181.65 - Last - Wheel Cylinders  |
	Regards (The mad Sarf Efriken)  |
			 I'm fitting bike throttle bodies (from a 600 Honda summat), got two sets which easily split into pairs so I can run three pairs straight down the middle.  Got to make up an inlet manifold yet which should be fun.  I then plan to use an Emerald ECU for fully sequential injection, just got to find one at a sensible price.
			D.
	visit my website at www.cossie.davenewell.co.uk  |
			 Any reason for sequential? Do you have a cam phase sensor?
			 This poll is missing an ........ I aint got a friggin clue  option !!??
			     Seriously though, my roots are firmly rooted to the carb era, that said, I very open minded about all options. I guess that is why I have a collection of the following: Original stock ecu, megasquirt, megajolt, stock injection, bike throttle bodys, bike carbs, access to a pair of twin webbers if needed & heck I even have a pair of Stromberg CD150's kicking about ( Yeah I know they were crap )   Who knows what my build will eventually end up with ![]()
	I am not a complete idiot...........Some of the parts are missing !! Ronnie ![]() www.roadster-builders.co.uk  |
			 I started to look into making my own throttle boddies a year ago when I had access to a lathe and milling m/c. It can be done very cheaply, even bought brass sheet for the butterfly's and brass rod for the spindles. Block of aluminium offcuts are not expensive. Would have to source linkages and springs etc. but using bits of old SU's or such like is a possability.
	Anyone in the Rugby area with machining facilities willing to give it a go?  |
			 Throttle bodies and megasquirt - 1st option
			Bike carbs and megajolt is a good cheaper alternative though, as long as your not worried about fuel economy.
	Haynes Roadster / Saturn GRP Bodywork. Now available direct through http://www.gillhamonline.co.uk/ or contact me direct on andrew.hugill@ntlworld.com Regards..........AndyH  |
			 Sequential because when its properly set up it works really well, cam phase sensor, hmmm, not sure to be honest but I'm sure if there isn't one I can come up with something
			  .D.
