#33
![]() Handbrake low effort for 3rd year running, so suspect another caliper.
Front Brake pipes incorrectly routed and rubbing ( subframe drop job ) Number plate lamp Advisorys on pitted disks ( it's done 3K in 2 years ) Cracked screen ( VOSA man was there and it was 100% by the letters, so the fact that the crack was right in the lower passenger corner but in the swept area "Actualy the Parked possision!!" Mr VOSA said no.. so that would be another £60.. And the emissions were out for the second year, it had a main cat last year. But the work to find out if it was that or one of the other two cats was going to get expensive!! It was £350 before the screen and emissions work And I suspect a headgasket leak on one bank anyway... Not worth spending that much on ( MK1 Si 2.5 with RS Pack. ) .. I will probably be braking it eventualy... TT
