Old 15th February 2010, 08:54 PM
james3004's Avatar
Default fuel tank injection
I just ordered one of 'andy's bargain find' fuel tanks, as i'm gonna be runnung an injection engine will i have to put a swirl pot on the bottom of it?
And where abouts have you guy's that have already got one put the vent?
--- James ---
IVA passed 20 June 2017
Flickr Album
Old 15th February 2010, 09:01 PM
Enoch Enoch is offline
I have the same question, I ordered one too I want to use the standard Sierra pump and sender but not sure if that is possible until I have a look at the tank and pump. I think that it may not be possible as the pump needs to pick up from near the bottom of the tank so some creative engineering may be required. Sorting out a return is dead easy, it's just a pipe inlet, if using the standard submersible pump the return is built in to the mounting plate, the same as the outlet pipe. Hope that makes sense....
Old 15th February 2010, 09:12 PM
james3004's Avatar
I hadn't decided on the type of pump i was gonna use yet, will probably go for an external one like the escort xr3i used to have
--- James ---
Flickr Album
Old 15th February 2010, 09:23 PM
I think the cap is vented, there's a small hole in it.
