Old 20th February 2010, 05:58 PM
GraemeWebb's Avatar
GraemeWebb GraemeWebb is offline
Wink
Originally Posted by dogwood View Post
I bet I hold the record for the most grinders burnt out during the build......
8 so far and still counting.......
Admittedly they were cheap as chips..7.50€ each
I know I know, I could have bought a good one instead of loads of cheapies.
But I also burned out my best Bosch one.
My B&Q cheapy went to angle grinder heaven about 15 mins ago, just when I was thinking that it was lasting well. That will teach me. Thinking - its just not me.
Old 20th February 2010, 06:03 PM
my grinder is the cheapo Machine Mart one , £22 , its been well used, built my car & it now gets serious use at Saturn, a great bit of kit for the money
Old 20th February 2010, 06:32 PM
Cool Looking good
The engine mount's are looking tidy Ginge
Don't remind me of cleaning donor parts .... Can't say I am looking forward to that Job
I guess that's why it hasn't been done yet
Old 20th February 2010, 07:11 PM
Electrolysis is your friend!! Donor parts came up like new, and all you have to do is wipe them under running water when done, then get some paint on them PDQ!
Actually turned out to be a pleasurable experience, and had me looking for more rusty stuff to do!!
Adrian
Old 20th February 2010, 08:01 PM
Adrian
Can you clean 20 years of gunge of an engine?
Old 20th February 2010, 08:43 PM
Errrr well yes ..... That's what de-greaser and a pressure washer is for.
Electrolysis is a method of removing heavy rust scale .... very effective too
Going to need a MF Electrolysis tank to fit an engine in, dread to think of the damage you'll do to the engines internals
Old 21st February 2010, 11:50 PM
When you say "two coats of primer" does it imply spraying with a spray gun and a compressor, then cleaning up the spray bottle afterwards, or do you use aerosol cans for things like this?
Also, did you make holes for drainage in the mounts, or do you think there's no need?
