its 14.1mm
Measured both..
Small one seems to be about 13.7mm but may expand Big one seems to eb about 17mm but may close up. Hopefully I can confirm tomorrow what fits what. TT
The longer one (right) is what I have and it fits the escort rack. Which one is that pas/ non pas?
the long one is NON Pas..
The short one is 2WD PAS.. I am fairly sure 4x4 PAS has 2 UJ's and no rubber dog chew. SO Back to Tallon... It will be about 1m of the tube.. TT
I would also be interested as well as I havn't made this piece yet.
i feeling that some one could make some money on this one, i need a bit too
#18
I will measure the approximate length again later. And confirm the fittment of the joint on the rack.
#19
1 Meter should be more than sufficient.
#20
And the thin shaft fits the escort rack.
So I think I need 15MM ID tube. I would sugest if you want to be sure that you measure your own shafts though MR Tallon...... TT
