Old 21st February 2010, 09:15 AM
Could you do a demonstration Ash ( video ) of what the tester did..
Are say for example the corners at the bottom of the headlamp round tube not an issue?
And from what you say, the sphere has to pass into Areas ( shock area ) if the can, so a grill is required to prevent issues with edges inside the nose??
