Old 21st February 2010, 09:06 PM
Enoch Enoch is offline
I did mine today, same is Ginge. Only bit I did that he didn't mention was to tack them then make sure the bones fitted exactly. I must have measured a dozen times, everything has fitted together perfectly. Be sure to pick a known datum then fit the bones temporarily, make sure everything is correct and only then apply copious quantities of weld. Simplez.....
