Old 25th February 2010, 07:33 PM
Originally Posted by DaddyA View Post
Andy,
the way I looked at it was, the weight would be directed downwards so putting the weight on the rubber.
If I angled it, surely the weight would be trying to push the mount away????
We'll have to see once its running
hopefully it will be ok, or i'll be making a new mount (hoping thats all i'd have to make).
Daz.....
I totally agree with your logic as i too thought the same & had intended to make mine the same as yours,
my question is just based upon , when i looked at the original alloy engine mount from the sierra it has the mounting point at the chassis end lower than the engine end, & so thought i,d try to replicate that positioning ( not easy i know due to the Roadster steering column position).
I,m not questioning the way you have done it, more a case of questioning my own thought process of my mounts.
