Old 5th March 2010, 07:47 PM
I like to leave the tranny tunnel exposed, comes in handy for a quick inspection, refix handbrake switch or speedo cable or adjust handbrake.
Personal choice though.....AndyH
Old 5th March 2010, 07:52 PM
That was more or less my thinking Andy
I also felt it would be a nice collector of every lump of garbage that comes its way
Old 5th March 2010, 08:32 PM
layotn20 layotn20 is offline
when fitting the rear ali for where the seats are. do u just cut to size and pop rivet as it is, or do you have to do something to the edges (clean them up/round them or sumit)
Old 5th March 2010, 08:46 PM
fabbyglass
Cut the sheet so it's just shy of the radius on the tube so when it's on you won't have a sharp edge.
Old 6th March 2010, 10:05 AM
james3004's Avatar
I'm going to do the floor, sides, rear panel (and maybe bonnet) in ali, so how many sheets of what size and grade will i need?
--- James ---
IVA passed 20 June 2017
Flickr Album
Old 6th March 2010, 12:26 PM
3 sheets without bonnet. 4 with. there will be enough to make a fuel tank out of that too.
Old 6th March 2010, 12:33 PM
james3004's Avatar
So that would be 3 sheets of say 1.0mm (sides rear, bonnet) and 1 of 2.0mm (floor)
--- James ---
Flickr Album
Old 8th March 2010, 08:21 AM
correl correl is offline
when I get as far as the ali for the tunnel my plan was going to be, get some bolts and weld the pointing down on the inner edge of the tunnel and allow the ali floor to run on say 15mm so they are poking through hole's then make a piece of ali the same size as the tunnel and drill holes in in so the bolts come though to hold it up and then use nylock nuts and cut all the bolts so they don't sit proud. This way the prop is covered but with a few bolts your in and able to work on things
Even when I do something the same it's a little bit different lol
and don't forget to Drive it like you stole it!!!
Old 8th March 2010, 10:25 AM
For covering the bottom of the tranny tunnel, separately, the best thing is just to drill a few rivnuts and use button head bolts.
Old 8th March 2010, 11:27 AM
Only problem with that way they could work loose over time and one day your driving along and hear a scraping noise. With the nylock nuts they won't undo on you and cause you grief.
