Ill be asking alot of probaly very obvious questions as i dont know much about wiring this engine. Thanks Edit: just saw your other post. i have connected the plug fromt he front body loom to the +12v. Now to figure out what the yellow.black wire is meant to be? it goes to pin 10 of the edia and the engine managemnet relay according to the haynes diagram
my build pics Last edited by geeman : 6th March 2010 at 04:55 PM. |
If you haven't got a manual, i've got an electronic version of the wiring i can send if you want??
I have that, its just im still no good with this wiring ![]()
my build pics |
EDIS? Are you runing megajolt?
Black Yellow, Goes to the ignition relay and fuse 20, 21 , 22.. Maybe some more items but bascaly It's Ignition Live Feed. TT
you'll just have to do a bit at a time, be careful because the wires tend to change colour as they go along!!
umm.. sorry again, didnt mean to say edis, meant to say hybrid ignition module. , imm really not doing to well here am i ![]()
my build pics |
ok, for the time being, as i dont have an ignition swith, and am just trying to get the engine running, can i just connect the black/yellow to 12v and that to the relay and the hybrid ignition module, ?
my build pics |
#18
Do you have the engine loom with the three multiplugs ( 4, 6 , 8 pin ) Still intact.
It's 10 years since I have worked on a CVH but the wiring to the engine hookup is the same for all post 90 cars. TT
#19
are those the 3 that join the main loom to the engine loom. I have attached the 4 and 6 pin ones, however, i cant find anywhere to attach the 8 pin one. Thanks for the help so far!!!! Also i just realised that relay that the starter solenoid wire is connected to is an auto trans relay? WHats this for considering i dont have auto trans?
my build pics Last edited by geeman : 6th March 2010 at 05:10 PM. |
#20
There's 2 different loom diagrams for the 1.8 CVH manual ( GR8!! )
Do you have Relay X1 or not? TT
