Old 7th March 2010, 11:02 AM
fabrun fabrun is offline
sorry jonB, i never had time to invest in FEA
Old 7th March 2010, 08:51 PM
hi john welcome to the forum. do all cars on oz have to pass that test? i believe the torsional data should be available as it was done when the chassis was designed as chris and martin got a chap on locost builders to run it through some FEA software.
Old 9th March 2010, 04:40 AM
jonB jonB is offline
Hi Guys
Thanks for that.
Yes all owner built cars have to pass beam and torsional testing.
I have read that there was FEA analysis done on the design but i cannot find any results.
thanks
jon
Old 9th March 2010, 10:35 AM
You may find that beam deflection & torsional rigidity testing is down to your engineer,some may require some not.I know here in WA we dont need to do it legally but also we dont need side intrusion panels/bars either.
I would join a car club in your area and talk to members about who they recommend etc as an engineer to use,some are more sympathetic than others.
Old 13th March 2010, 11:59 AM
update with the différentiel
on the ground (bottom view)
after 3d modeling
Old 13th March 2010, 12:06 PM
inside the chassis
Old 13th March 2010, 12:09 PM
a cut for a better view
