Old 9th March 2010, 04:52 PM
I totally understand your reasons for wanting to cut your own chassis, i really do understand that,
The price for a Flat pack kit which includes the following....
All square tubing to fabricate the main frame of the chassis (25mm & 20mm)
All angles cut & each end marked with the angle of the cut ( to allow easy orientation of the tube when using the book build info), also each tube has its I.D code ( TR1 TR2 etc)
The Front Frame is supplied jigged & fully welded.(saves making the jig)
Also in the kit is a paper template for your build table ( shows the position of the bottom rails)
All the above is £230 plus £40 delivery (tho you are welcome to arrange your own courier or collect in person etc)
Again, I,m not trying to "Hard sell", just trying to offer a good product at a fair price.
