![]() yeh hope so, iv just welded in a boss for a lambda for the Rolling road, spoke to a chap eirlier said it should be a doddle..
as for the rest a few evenings should sort it tilly |
![]() think the i got the front arches second hand carnt remember were from, dont have a recipt...
drive home was great ....... saw 2 rozzers one on a island wouldnt have seen that is didnt have plates and the other drive straight past me with nothing elce on the road, to be fair i had a IVA TEST plaque stuck on the back tilly |
![]() Oh think iv found out why its running so rich as well.... when i was on the phone to the chap at the rolling road i told him id removed the stock air box and fitted the ITG socks and he sais they are rubbish and really restrictive, once took a set of a street car and emidetly gained 10HP lol
tilly |
![]() Thats not bad at all well done!
Hope my list is as easy to fix as that ![]() |
![]() Just out of interest .... How is your roll bar fixed .... In particular the backstays .... One bolt, Two bolt's or welded
![]() Just thought it would be usefull to know & gauge if there are variations between test centres ![]()
![]() Well done Tilly, that really is a good result.
If it wasn't for the emissions failure you could have got the rest fixed over the lunch break and passed on a retest on the afternoon. Well Done, easy pass next time. Sounds like you had a very practical, nice, helpful tester. Same as mine - was very pleased. AndyH..... ![]()
![]() awesome...
Take some picks of all those tricky areas we need to beware of and give us the rundown on any tips. Good luck for the retest ![]() TT
![]() Congratulations on getting the IVA, I'm positive those few items won't stop you and you'll have a retest shortly.
I'd also like to know about the rear roll bar braces / supports with regards 2 bolts / welding. All the brackets I have for my brake T-Pieces are aluminium ![]() |
![]() hi all my roll bar is welded down...and he did check it but litraly looked and saw it was all welded in and said it was fine,
as for the arches i honestly carnt remember where igot them but basicly if you put a plum bob down from the front of the arch it has to cover the full diamitor of the wheel front to back and side to side. then the tyre is the 30 deg forward and 50 deg rearwards easy to do if you havnt mounted the arches yet just mount then further forward. tilly |
![]() ps provided the plates that your T peices are on deezee cannot vibrate or resonate basicly they have to be stiff..they should be ok mine was just abit flexable
