Old 9th March 2010, 06:53 PM
seems like you did pretty well. cant believe how quick your test was. did you have one or two testers?
only bummer is that you are going to have to spend out on a power commander but then again you was planning to anyway. did you try the emissions again with the air filter off? may be worth running outside tonight and seeing if it runs ok with them off.
also what did you get on the noise test?
well done mate i could hear the nerves in your voice yesterday but like i said it wasn't that bad was it.
