Old 17th March 2010, 08:40 PM
your suggestion of an ali strip is a good solution.....
BUT
Do NOT run the fuel lines on the same ali strip as the electrics,
I,ve basically used a corner of the tranny tunnel for each ....fuel & brake lines at the top of the tunnel & electrics at the bottom.
Tho Spud has an ali strip like your suggestion but with the electrics away on their own.
hth
