Old 17th March 2010, 09:40 PM
Eternal Eternal is offline
Default Tig welded chassis
Hay guys just a quick question to see how many of you have tig welded chassis?
Old 17th March 2010, 09:51 PM
geeman's Avatar
geeman geeman is offline
I tig'd mine all the way, as ive never used a mig welder before, only tig. I didn't have anay probs, apart from it being slow, but it didnt really bother me.
my build pics
Old 17th March 2010, 09:55 PM
mine is a mix of mig and tig. tigged all the pretty bits and migged all the hard to get to bits.
Old 17th March 2010, 10:23 PM
I used tig on my chassis and wishbones. Simply because thats was the only welding set I could get for free. Its very relaxing, if nothing else. Although required two hands does mean you tend to need a lot of clamps etc to hold things in place.
Old 18th March 2010, 07:28 AM
Cool. The idea for using tig and mig for hard to get to bits is a great idea. Thanks a load guys!
Old 18th March 2010, 08:40 AM
Enoch Enoch is offline
Just to be different I arc welded mine. I think you get a much deeper, stronger weld on thick gauge material with arc - it's a debate that has been had many times now I have a 200 amp jobby, most of the time I use it at an indicated 90 amps, the rear uprights required 130 amps, still well within the capabilities of the machine.
Enoch
Old 18th March 2010, 05:15 PM
I started with the TIG ..... Soon got bored !! Me all over, i'm afraid
Dragged the MIG out PDQ
Enoch
Looking at your build diary .... Looks like you are doing a darn fine job with your trusty Arc welder
If I had some decent electrodes to hand, would have used the stick welder on some of the heavier stuff myself.
I still enjoy stick welding & don't have a lot of chance to do so, as often as I used too.
Old 18th March 2010, 07:13 PM
Fanks Ronnie I am going to take some pics of my rear uprights soon and also some of the side infill panels, just to show what a flexible machine it is. It does TIG as well but I have not had a go with that yet.
Enoch.
Old 18th March 2010, 08:10 PM
squbti's Avatar
squbti squbti is offline
I also TIG welded everything from chassis to wish bones & uprights. it didnt take a long time & i have no spatter & will not have to grind any joints at all not even the ones on the outside where the side panels go so i think it turned out realy well . TIG is king
samy
Old 18th March 2010, 08:13 PM
Originally Posted by squbti View Post
TIG is king
samy
Can't argue with you there Samy .... Just need the patience of a Saint .... That's all
