Old 22nd March 2010, 07:01 PM
geeman's Avatar
geeman geeman is offline
Originally Posted by Tatey View Post
Could you not diagnose the fault and then fix it? e.g. if its smoking a lot then it could be the valve stem seals?
im sure its not them, not blue smoke, its very dark sooty smoke, soot is settling on the floor around the manifold when i rev it. Its not a fuel mixture problem either.. i think. I also put new plugs in a few days ago, and the tips are already completely blackened and covered with carbon.
edit: I have no idea how to diagnose the problems either. I did a compression test on it today as well i got them all at about 95-105 psi. Any idea? im really hoping to find a cheap cvh that'll probably be cheaper than fixing the engine.
my build pics
