Old 27th March 2010, 09:52 PM
eSteve's Avatar
eSteve eSteve is offline
DogWood,
that looks neat and tidy, good job. Is that low enough to count as an aeroscreen? How high is it from the scuttle? Where did you source it from?
Regards,
eSteve
Old 27th March 2010, 10:36 PM
The problem with making wind screens for the roadster is that it depends on who has made the scuttle. If you have made your own how different is it from any other you can buy from the various body work suppliers. SVA test for the glass is the same for the IVA ie it needs to be laminated and kite marked. You can get the correct glass from any commercial glaziers as it's used in some shop windows and jewellers counters as safty glass. The ali channel frame can be made by using the method in the book using the former. Any way what do you want a screen for, It's not very hard core is it? Might as well go buy a MGF lol
Old 28th March 2010, 08:24 AM
dogwood's Avatar
dogwood dogwood is offline
Originally Posted by eSteve View Post
DogWood,
Not sure how high it is off hand, I'll measure it when I get in the barn.
But it is defo low enough to be an aero screen, and ya can hucker down behind it if it turns orrid.
I got it made at my local glass supplier.
It's toughened glass though, rather than laminated.
Took him in a template. cost me £18.
David.
Old 28th March 2010, 10:03 AM
MGF,s are for hairdressers,and not Roadster buliders !
Not real cars anyway,one Metro subframe was bad enough and then some twonk fitted two
Old 9th May 2010, 09:50 PM
David_17's Avatar
David_17 David_17 is offline
Is perspex/polycarbonate acceptable as opposed to kitemarked glass?
Old 9th May 2010, 10:38 PM
Absolutly not.
Old 10th May 2010, 04:25 PM
David_17's Avatar
Not even as a fly screen?
Old 10th May 2010, 05:57 PM
There will be some sort of rule as to what counts as a fly screen, they can be made of anything so long as they are not classed as a windscreen. But you may as well go with a black Fabby one as your not going to see much through a tiny Perspex fly screen anyway.
