Old 27th March 2010, 10:35 PM
SeriesLandy's Avatar
Different rose joint with a smaller hole????
Old 27th March 2010, 10:39 PM
layotn20 layotn20 is offline
http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWAX:IT just bought these. hopefully that will do. this as give me a head ache all day
Old 28th March 2010, 09:51 AM
Yes that is the one but now seeing your problem Steve is probably right in thinking new joints to fit the bolt you are using.
I used a 240mm long cap screw for the lower bolt( high tensile steel)
It is better to use something not completely threaded,the difference between screw and bolt.
Old 28th March 2010, 04:49 PM
fabbyglass
Sleeve the imperial rod ends as most metric rod ends are not rated the same.
Old 30th March 2010, 09:54 AM
my reducers i ordered have come today really good fit. if i use these will they be ok for the iva man.
Old 31st March 2010, 04:50 PM
reducers turned up, and there rubbish. ordered some 240mm tensile steel bolts there to long. im really getting annoyed now nothing is going right
because the bolts are to long for the bottom of the up right can i just use the bush tubes as spacers??
also ordered 2x240mm tensile steel bolts for rear diff/bracketts same case here bolts are about 20mm to long. can i space these with bush tubes also??(is that ok for iva man)
when i say to long i mean all the thread is through the other side and some of the smooth shaft of the bolt, so obviously if i got to tighten the bolt up it wont because there isn't enough thread. if that makes any sense.
Old 31st March 2010, 05:48 PM
The original diff mounting bolts were M12 X 210mm & they are plenty long enough for the job
Some better pictures of your rear suspension set up would be helpfull so as folk can give you some more detailed advice
Old 31st March 2010, 07:01 PM
is all thread for the diff brackets iva passible?
