Old 8th April 2010, 04:01 PM
geeman's Avatar
geeman geeman is offline
ok, i was doing the rear arches and wondered if the gap between the tyres and the arches is meant to be as big as this:
The reason is the arches are already thouching the bottom of the chassis and looking at spuds car in this pic, his gap isnt as big.:
im using 15 in rims and 97.5mm wall tyres...
my build pics
Old 8th April 2010, 04:28 PM
gingea1pom's Avatar
Geeman,
I hate to be a geek but the ‘50’ in 195/50/R15 is a percentage of the 195. The walls of your tyres are 97.5mm tall.
I cant help with the ride height problem though except to say if you put a full tank of fuel in and get two people sat in it will that make a difference?
Cheers Ginge
Build Pictures
Old 8th April 2010, 04:31 PM
geeman's Avatar
Geeman,
amended
Cheers Ginge
hmmm.. should have thought of that.. i guess i'll be fine as the arches wont go any lower on the chassis
my build pics
Old 8th April 2010, 04:39 PM
gingea1pom's Avatar
Geeman,
Ref. ride height I haven’t got that far yet so am probably talking out of my a*r*.
I am stuck at my brother-in-laws in Manchester with nothing to do but check the forum. May be I should stop posting and just read!!!
Cheers Ginge
Build Pictures
Old 8th April 2010, 04:54 PM
Geeman, Don't you have your rear hubs on steel tubes, rather than on shocks?
Old 8th April 2010, 05:12 PM
geeman's Avatar
yes, atm, i havntn bought the shocks as they are expensive...
my build pics
Old 8th April 2010, 06:01 PM
Tatey's Avatar
Tatey Tatey is offline
Looks like we've found your issue then . The shocks will compress even when no one is sitting in them as there is still a lot of weight over the rear end from the diff, chassis, fuel tank and body work, where as the tubes wont.
