![]() my diff is terribly our of line with my gearbox, mainly due to my badly drilled diff mounts, im going to slot the diff mounts horizontally, and the diff brackets vertically so i can adjust the diff as much as i need to.
my build pics |
![]() I had a nightmare fitting my diff, it took me hours to get it right. The checks I did on mine were - check level of output flanges (ie both at same height), check output shaft central in trans tunnel and check output flange square to chassis. I don't think it has to be perfect and doubt it was in the donor car but getting things spot on at this stage can save a lot of tears later. Take your time, check and double check and it will come out fine.
