![]() Quote:
![]() the ones i used are nylon p clips from maplin, they are cheap and i think they should be fine for iva. they are sold in packs of 100 which is enough as i still have a quite a few left over.
my build pics |
![]() i used plastic maplin ones for the brake pipes electrics and fuel lines, went through iva without a mention.
![]() Mainstream use push on, so should be fine
![]() What size P clips are used 6.4 or 3.2
![]() These are great p clips tk:
http://www.cbsonline.co.uk/stainless...5ss-1482-p.asp not very cheap but when i took mine for sva the examiner commented straight away how well they looked, just helps to get you off to a good start. AndyH
![]() Spud
I'm not tight ![]() How mant do you reckon you got through completely? ![]() |
![]() [quote=tkpm;35831]What size P clips are used 6.4 or 3.2[/QUOTE
6.4 for brake lines from memory. |
![]() and 9.5 for fuel lines, and a mix of the 2 sizes for electrics
my build pics |
