Old 12th April 2010, 03:08 PM
If your going to mount it on end, make sure you header tank is way above the rad's inlet/outlet and idealy fitted with a level warning..
Otherwise, if the water drops too low the water may not pump out of the outlet, and also the thermo switch may be high and dry...
