Old 12th April 2010, 04:51 PM
Default oil pressure / temp gauge
Hi all,
I,m about to fit an Oil pressure gauge & an Oil temp gauge, obviously I know where the original pressure point is on the block, so was thinking if its poss to fit both senders for pressure & temp from the same place on the block, or is there another outlet i should use for the oil temp sender?
I,ve read that i would need a "sandwich plate fitting" to connect both from the same outlet but its very close to my engine mount & don,t think i,ll be able to fit anything that size so close to the mount.
any suggestions ?
engine is the 1.8 CVH
Old 12th April 2010, 05:15 PM
Sandwich plate sits in between the oil filter and engine. I had one on my MR2 turbo for oil pressure and temperature. Super handy. Shame the Ford fitting isn't the same as a Toyota.
http://cgi.ebay.co.uk/SANDWICH-PLATE...mZ360249743117
Old 12th April 2010, 05:22 PM
ahhh, cheers deezee, i thought the sandwich plate went where the original pressure sender is,
that helps as i think there,s more space at the filter
Old 12th April 2010, 05:29 PM
where do i get a sandwich plate from?
Old 12th April 2010, 05:49 PM
Ebay, Burtons, Rally design anywhere like that.
Old 12th April 2010, 06:19 PM
gingea1pom's Avatar
Andy is this the sort if thing you are after.
Cheers Ginge
Build Pictures
