Old 12th April 2010, 05:15 PM
Sandwich plate sits in between the oil filter and engine. I had one on my MR2 turbo for oil pressure and temperature. Super handy. Shame the Ford fitting isn't the same as a Toyota.
http://cgi.ebay.co.uk/SANDWICH-PLATE...mZ360249743117
Old 12th April 2010, 05:22 PM
ahhh, cheers deezee, i thought the sandwich plate went where the original pressure sender is,
that helps as i think there,s more space at the filter
Old 12th April 2010, 05:29 PM
where do i get a sandwich plate from?
Old 12th April 2010, 05:49 PM
Ebay, Burtons, Rally design anywhere like that.
Old 12th April 2010, 06:19 PM
gingea1pom's Avatar
Andy is this the sort if thing you are after.
Cheers Ginge
Build Pictures
Old 12th April 2010, 06:32 PM
NOOOOOOOOOOOOOOOOOOOOO
Oil cooler sandwich plates are for use with an oil cooler only. Do not try and plug sensors into them. Otherwise the oil can't reach the filter!
Oil cooler sandwich (note oil MUST flow out out)
Oil filter sandwich (Note the oil flows past the sensors and into the filter)
Old 12th April 2010, 06:37 PM
All that hassle for a sandwich....
