![]() If you are going past Bracknell in the near future bring em along and I can drill em and tap em for you.
Dave. |
![]() Enoch,
What are you up to on Thursday; ![]() Cheers Ginge
Sent from my iPad, from who knows where in the world I was building but I am not now! ![]() Build Pictures Build Thread |
![]() Hi Ginge,
Build is looking good on your build thread. They look like course threads on the grub screws, Depth of thread = 0.866 of the Pitch of the thread so 8-(0.866x1.25)=7.02mm so a 7mm drill would be fine for the M8 thread. Plus the cast of the upright taps easy. Keep it up....AndyH
![]() You can get a cheap tap and die set that goes from m4 to m12 for about £25 it will even have the wrenches in
No good for everyday use but fine for the odd bit whilst building your car |
![]() Spud, it's not that simple. Both ends of the triangular profile are beveled, and the nominal diameter of the thread is not measured at the tips of the triangles (Dmaj+H/8), but the actual height of the external thread (Dmaj), so the math is a bit more complex. The drill diameter is Dmin here.
![]() More info on wikipedia, as always: http://en.wikipedia.org/wiki/ISO_metric_screw_thread
![]() OH MY GOD
That diagram / drawing is awesome if not a little mind bending. 6.8mm then!!
![]() Get your self a copy of the 'Zeus' book. A brilliant pocket book full of all sorts of useful engineering info. Your overalls shouldn't be without a copy!
Gallery 2 http://www.facebook.com/album.php?ai...4&l=a9831a9319 Gallery 3 http://www.facebook.com/album.php?ai...4&l=3f0d42c523 Gallery 4 http://www.facebook.com/album.php?ai...4&l=efb083b7df Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5 cd3a Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=1&l =fe779b358c |
![]() Ginge, I have an MOT first thing in the morning, I need to spend a few hours in the office and expect to be home at about 3pm. I will PM you my phone number so you can call and see if I am free before coming over.
Dave. |
![]() sounds perfect to me
