|  Oh Yeah.... it will deffo fit So if your ever tempted by Car Builder Solutions to get a wiggly hose, the kind that will defiantly fit over a 32mm pipe, take it from me, its the worst fit ever! Now it clearly will fit, but this is as far as it goes. Save yourself the hassle and bother and get some proper hose elbows.  |
|   warm it up it will stretch.
				__________________ My Roadster Is Finished NerNer....... Pigs can fly, you just have to carry them onto the plane. My Pictures http://s707.photobucket.com/user/ashgardiner/profile/ |
|   And WD40 the rubber. TT
				__________________ You only get a woosh with a dump valve Build Thread Man Cave Mantiques Cecil Street Auto Repairs Garage Carlisle Build Cost £4181.65 - Last - Wheel Cylinders |
|   This was after it was sat on my radiator!  I took my calipers to it and it only measures 26mm ID.  I would have thought any 32mm hose would be around 30mm ID. |
|   Thats a big stretch Deezee, from my experience the constant heating and cooling will perish the stretched rubber over time and it may crack.  Not worth the risk Deezee......AndyH
				__________________ Haynes Roadster / Saturn GRP Bodywork. Now available direct through http://www.gillhamonline.co.uk/ or contact me direct on andrew.hugill@ntlworld.com Regards..........AndyH |
|   I wonder if you were sent the correct one? Sizes seam way out, I'd check with them and if it's correct ask for a refund as it's not even close to the discription on ID size stated in their discription. J |
