![]() HI, When i did my rear hub carriers i removed the hub and used the lids from tubes of grease with a few rounds of insulation tape on them pushed into the seal either side ths stopped the water solution getting at the bearings this worked really well
i did remove the seals and bearings after for cleaning but managed to use all the old bits again as they looked good as new anyway hope this helps Ray ![]() |
