Old 10th May 2010, 05:21 PM
David_17's Avatar
David_17 David_17 is offline
I wouldn't be bothered about private plates. So would it get a '10' plate?
Old 10th May 2010, 06:55 PM
No, you would have to build from virtualy all new parts to get a 10.
You will get the Donor car reg if you can prove you have used most of the major components needed from that donor.
You will get a Q if you can't prove the origin of the donor parts were from one source.
