Old 10th May 2010, 08:02 PM
mark mark is offline
Originally Posted by gingea1pom View Post
Nice one Mark,
Really am pleased for you.
Did you have your roll bar rear stays bolted down with two bolts each?
Cheers Ginge
My rear stays are made fom the same diameter tube as the hoop supplied by ash and extend down to the most outer lower point of the chassis where they are bolted through 8mm gusset plates with a m14 bolt. Just one bolt in each side but quite a hefty one!
