![]() Teun,
Could you elaborate on the kit from pepper as was looking at this route. Are the parts supplied shit or of no use to achieve a good fit or ???? |
![]() When you weld up a collector, you normally bring the pipes together, tack them so they all touch - then make an infill piece to cover the gap between the pipes where they join and weld that in. You then slip the collector over, and weld all around the outside of the pipes. This should then give you a full sealed collector.
This will explain it better - http://www.coneeng.com/weld_on_collector_kit.html but instead of having the merge bullets you fill the gap with a bit of flat plate.
Gallery 2 http://www.facebook.com/album.php?ai...4&l=a9831a9319 Gallery 3 http://www.facebook.com/album.php?ai...4&l=3f0d42c523 Gallery 4 http://www.facebook.com/album.php?ai...4&l=efb083b7df Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5 cd3a Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=1&l =fe779b358c |
![]() Ozzy1 i did buy the kit from pepper performance i did get a big bag full with differend pipes. I think about 15 pieces different size's some are straight some are bend if i do no forget i take a picture this weekend. The collector doesn't fit because it is to small. I would think twice to order the set.
![]() Hi all, Thanks, Tuen, I was a bit worried about spending that sort of money as the pictures they have on ebay are not very clear and I like to know what I am getting.
Andy, as far as I know the manifold I have is thge only Ford one that fits, I don't know if the unit from a 16 valve version would fir or if it would make life easier. David, thanks a lot for that web link, that really helps a lot. The pepper pipes don't seem to go together anything like that but it shows a bit of the process. I have emailed papper so I will let you know what they say. I have asked for some dimensions so I can see if it can be made to fit. I may have to just modify my down pipes. Thanks for the replies, I will let you know what happens. Best and all that, Enoch |
![]() Hi Enoch,
From memory, I'm pretty sure the cast manifold you have is the only one made for that engine. The 16v head/manifold is totally different. It might be possible to use the 16v one if you cut the flange off and make one that suits the 8V head but thats a lot of biggering about in my opinion. Make something to fit the stock 8V outlet - possibly adapt the original downpipe. The 8V is not a high performance engine so it's not like it's gonna affect performance much using the stock manifold. HTH BV ![]() |
![]() Well I had a very long chat with Spencer at pepper performance, he seems like a really helpful guy and spent quite a bit of time telling me how his kit goes together. It is somewhat helpful that he has a roadster there which he can use to make sure it will all fit
![]() Enoch. |
![]() I'll second that Enoch
Spencer gave me some first class customer service & really went out of his way to help me ![]() ![]() ![]()
