Old 27th May 2010, 03:34 PM
Are you bleeding the brakes on your own using a one man bleed kit or doing the mate/wife/other on the pedal while you open/shut bleed nipple method? Are you using vac servo mc or a non servo unit?
I've just had a days worth of fun with my heinz 57 escort van trying to get the front to lock before the rear. Found out the light laden valve is not working and the rear drums are warped, great for left foot while power on hand brake type turns but scares the s**t out of oncoming traffic!
Old 27th May 2010, 04:02 PM
Johnnybizzle Johnnybizzle is offline
Thanks for the quick response quys i will have to persist and keep bleedin at the weekend with the missus
Old 27th May 2010, 08:03 PM
Neil P Neil P is offline
Check your brake pedal push rod height is level with the master cylinder.
I had a hell of a job getting a firm pedal on my brakes. Not sure if it's an amended spec now but the position of the hole in the brake pedal was incorrect in the original book. This means that the pushrod is pointing up at an angle so rather than applying direct pressure to the M/C it starts to fold towards the back of the pedal.
It gave symptoms of air in the system and I had low brake effort at SVA. I have no idea how much brake fluid I ran through it.
It was a real 'eureka' moment when I found it!
If you are working to modified dimensions, then the above will be of no use whatsoever.
Neil
Old 27th May 2010, 08:52 PM
trickydicky0_16 trickydicky0_16 is offline
Hi
Are the calippers on the right way (i did this) changed them over apresto they work
Old 6th June 2010, 06:53 PM
Well after taking advice, i have taken off the rear calipers turned them the right way up and re bled, They could now stop a steam train im well impressed.
Old 7th June 2010, 07:22 AM
This kinda thing happens, like i say i did this in the front....... lol better chek the back now....
