Old 29th May 2010, 01:55 PM
Josh's Avatar
Josh Josh is offline
Default Painting sierra parts
I've just finished all the electrolisis and wire brushing of all my sierra bits (uprights, calliper carriers etc) and want to get them painted soon before they start rusting all over again! What paint has everyone used, and whats the best method of applying it??
Thanks,
Josh
Old 29th May 2010, 02:18 PM
tkpm tkpm is offline
I have used Hammerite, brush and spray on uprights, brake back plates, drums, drive shafts, diff etc, and engine lacquer on engine parts.
Terry
Old 29th May 2010, 02:24 PM
gingea1pom's Avatar
Morning Josh,
I have applied two coats of acid etch primer then two coats of primer then top coat!
Just me mined
Cheers Ginge
Build Pictures
Old 30th May 2010, 11:21 AM
I also found Hammerite good stuff to use especially the smoothrite stuff if its on a part thats on display
Old 31st May 2010, 10:46 AM
Jezzer99 Jezzer99 is offline
I always apply a coat of Kurust before painting. As well as converting any last remaining traces, it seems to give a good solid base to put Hammerite on top of.
Cheers,
Jeff
http://berkshire7.blogspot.com/
Old 2nd June 2010, 08:07 PM
james3004's Avatar
i brought a powdercoating jobbie to do mine, only done one bit so far but well pleased with the results
--- James ---
IVA passed 20 June 2017
Flickr Album
