![]() Kev,
As above (double post) Now don’t take me as a complete authority on this but…. The LT77 gearbox uses a transfer box to create the 4WD, if you remove the transfer box you have a one out put gearbox. I am going to go and lay under a Land Rover to check the gear leaver attaches to the gearbox not the transfer box! Cheers Ginge Oh welcome, (good first question both my passions in one post) ![]()
Sent from my iPad, from who knows where in the world I was building but I am not now! ![]() Build Pictures Build Thread Last edited by gingea1pom : 3rd June 2010 at 03:09 PM. Reason: Coozer was quicker than me |
![]() Right I have just crawled out from under a Land Rover, I could only find an ambulance!
As Coozer said really, or you could leave the transfer box on stick the diff lock in and have the widest transmission tunnel ever but a prop shaft that is about 20mm long. Best search for a 2WD cover! ![]()
Sent from my iPad, from who knows where in the world I was building but I am not now! ![]() Build Pictures Build Thread |
![]() Welcome Rincewind, are you a Wizzard by any chance? I don't know much about landys other than they're uncomfortable animals but great off road, good job Ginge and Coozer have answered your question.
D.
visit my website at www.cossie.davenewell.co.uk |
![]() I have been thinking a little more about this. (No comments you lot).
My first 90 had an LT77 and was screaming in fifth at 60mph the later R380 is a little better, has reverse in the right place as well. I know the diff has the final say in the road wheel output speed but it might be worth thinking about. Someone must make a rover V8 to type 9 conversion plate, and then you won’t have to mess around modifying the transmission tunnel. Just thinking out loud. Cheers Ginge
![]() I have seen a couple of rover v8 to type 9 bellhousings either on ebay or the v8 forum but they arnt cheep. I have also been told by several people not to go down that route because the type 9 wont be able to handle all the extra torque!
In the end i have decided to go with a lt77 gearbox from a tr7 as the 5th gear is taller and is actually an overdrive gear. cheap too, only cost £47 for the gearbox and it bolts onto the sd1 bellhousing with no problems. |
![]() im not 100 % sure about that gearbox, im sure someone who knows more about gearboxes will have a look soon. The only thing i would say is that bell housing wont fit on the v8. As far as i am aware you also wont be able to use a 4wd bellhousing because they are too long......
