Old 4th June 2010, 08:13 PM
Hi James
Sorry to have misslead you a little .... When I say that the gearbox shaft is supported at the flywheel. I in fact mean, supported in the crankshaft.
for some silly reason I thought if I said flywheel it would be easier to understand
Forgive me, I have had a stressfull day
The spiggot bearing fits in the crankshaft ( This will be drilled, ready to accept the new bearing )
It is highly unlikey that you would be able to remove the old one without destroying it.
Probably be wise to use a new one in any event, there could be a fair bit of wear on the old one
Old 4th June 2010, 09:19 PM
james3004's Avatar
Not to worry Bonzo, a new one is only £15.56 with VAT and delivery from Ford parts direct
--- James ---
IVA passed 20 June 2017
Flickr Album
Old 4th June 2010, 11:31 PM
They're a lot cheaper at the bearing factors. Code HK1516. I got mine for 75p :-P, even though they're normally £2-5 depending on the make.
Old 4th June 2010, 11:59 PM
james3004's Avatar
After a search of the net i have found a drawing of the spacer that westfield araldite the the standard bearing
I think i'll get one made up at work but not really sure what the best material to use would be?
It says on the drawing that it has to me 19mm depth but, different people say different things ranging from 19mm, 19.5mm or 20mm
Thought other people might find this useful (maybe the andy's at saturn could undercut westfield on this and make it more available to the public )
--- James ---
Flickr Album
Old 6th June 2010, 09:58 AM
I would try making an extension tube to mount over the the clutch release bearing mounting tube to give as much surface area as possible for it to ride on.
Westfield must know what works and what does not,my humble opinion is that it looks like a possible problem in a fairly short time in the way it is "glued".
