Old 5th June 2010, 12:47 AM
Can it drop the pressure? Doesn't it just stop the pressure in the rear from increasing further? I think the rear is pressurised when the deceleration valve is closed, definitely enough for the switch. What do you think?
Old 5th June 2010, 08:18 AM
Enoch Enoch is offline
I don't know but good engineering practice says don't take the chance.
Enoch
Old 7th June 2010, 07:39 AM
axle's Avatar
axle axle is offline
Hi
Thanks for asking and your help. The car is comming along not badly work pressure is a bit too much but the car gets a little attention and does unwynd from work.
Regards Axle
Old 16th June 2010, 06:10 PM
here is how it works
its fitted angled with the input to the top/front angled to the front of the car
when you step on the brakes hard there is a little spool valve that travels uphill by enertia preventing the rear brake lines form increaseing fluid pressure
stoping the rear wheels from locking as the back goes light
so the harder you push the pedel the rear gets no pressure rise
the steeper you set the angle the harder it is for the valve to work
when your stoped and level the back should get full pressure
hope that helps
Old 21st June 2010, 10:41 PM
davidimurray's Avatar
This might be a really stupid question - but on the rollers for the IVA test will these deceleration valves work as the car is not actually physically decelerating
Old 21st June 2010, 11:14 PM
Twin's Avatar
Twin Twin is offline
Originally Posted by davidimurray View Post
This might be a really stupid question - but on the rollers for the IVA test will these deceleration valves as the car is not actually physically decelerating
Same for any car thats on test, weather new or old.
Twin
CSF £857.19
Twins Roadster
Old 22nd June 2010, 08:32 AM
So it would seem then that for our purpose of IVA there is no benefit in fitting one.
Old 22nd June 2010, 08:36 AM
Twin's Avatar
But! it will give you better braking benifits, I think
Twin
CSF £857.19
Twins Roadster
Old 22nd June 2010, 08:58 AM
I would have thought that when braking all the weight transfer will be forwards so the majority of the braking will be done by the front brakes and you will then become traction limited. At the back of the car, the weight will reduce and you will also become traction limited because of the reduction in load on the tyre - i.e. the rears will lock because they are lifting off the road and have a neglibile braking effort.
Old 22nd June 2010, 10:20 AM
I've heard off this before David and once the inspector has seen that the deceleration valve has been fitted he is confident that the rear wheels are not going to lock and will be okay with it.
Regards....AndyH
