Old 5th June 2010, 10:24 PM
onedayTM onedayTM is offline
Hi dan, what a lump, that should a nice ride. Although I am nowhere near seeing a engine in mine, but you probably need to mock up the scuttle height and also the nosecone and then run some masking tape bewteen them and that will give a line to work around. You will then see what clearance you have and whether you need to cut bonnet! If you dont have these yet you will need dimensions of someone and maybe mock up in wood .
tony
