Old 6th June 2010, 12:45 AM
gingea1pom's Avatar
Originally Posted by dan_g8 View Post
thanks headshot ill have a look on the net, hopefully someone will come along and spill the beans on how high the engine can be so that i dont buy/make one that is still too tall
Dan,
Check out this post the PDF should have the info you are after, if not give us a shout and I will search some more.
Hope it helps
Cheers Ginge
Build Pictures
Old 6th June 2010, 10:15 AM
This may help,set the ground clearance from chassis to floor at the front on some blocks at about 5 ins and the rear at about 6 1/2ins,see what sump clearance you have and possibly fit wings to sump to increase capacity lost through cutting the bottom off. Adding 25 mm brackets to top chassis rails and adding the same to panel/scuttle/noscone height etc will give you more under bonnet clearance.
And replace the exhaust manifold bolts with studs as they always failed on the SD1 of a million years ago.
Good luck.
Old 6th June 2010, 10:46 AM
dan_g8 dan_g8 is offline
thanks Ginge that post was exactly what i was after. using this and flyerncle's idear ill chop the sump next week. am i correct in thinking the sump should be about 25mm below the chassis?
Dan
Old 6th June 2010, 11:21 AM
gingea1pom's Avatar
Dan,
Here to help mate(cheesy grin smilly)
Try a serch using the key word 'sump'.
I can't at the moment as I am on my mobile.
Cheers Ginge
Build Pictures
Old 6th June 2010, 01:16 PM
Consider keeping it level with bottom of the gearbox Dan,you could always fit a bash plate to bottom of it to help if hit.
Should go pretty well when finished !!
Old 6th June 2010, 06:21 PM
Just be aware,
if you raise the height of the upper chassis rails to increase height of the bonnet...........
If you decide to use GRP side panels then they are designed to fit the standard chassis height of 355mm,
and also the nosecone is shaped to also fit the same dimensions,
yes you can raise the position of the scuttle but just wanted to highlight that the GRP sides & nose are made to be a snug fit
hope this helps in some way.
By the way, mighty impressive engine bay
