Old 13th June 2010, 10:02 PM
geeman's Avatar
geeman geeman is offline
Originally Posted by drury318 View Post
If you are using the cvh engine from the donor then no problems, get your engine number from the block or copy of V5, then write to Ford for confirmation of age or use the V5 copy to prove the age. Just make sure the engine number matches the V5 & hasn`t been changed at some time
Dennis
i guess ill be fine then, at least i no longer have the worry of needing an age related plate, infact ive been looking for a reason to get a different engine for some time, this may well be it!!
Thanks
my build pics
