Old 14th June 2010, 03:57 PM
Originally Posted by Josh View Post
All noted, I'll lower the engine until it just sits below the bonnet line then set about making a modded sump.
On a side note will an exhaust manifold from a Ford Focus ST170 fit to my 2.0L Silvertop Zetec??
Josh
Yes it will Josh you just need to cut a piece out and turn the exit bend so that it exits along the side of the car instead of underneath the engine as it would in a fwd focus. The ST170 is badged as a Duratec but is really just a souped up Zetec in disguise.
Can post some pics if you're stuck.....AndyH
