I have cut out the scoop in my bonnet and cut out a triangle on each side to aid airflow
So just thought i would share a snap with you all to see what you think! They are filled in with some black mesh attached with a hot glue gun It wasnt the most fun thing i have done taking an angle grinder to an absolutely perfect bonnet The reason i did it is all the air coming through the nose and rad has no where to go except under the car or down the tunnel. This also meant my carbs were sucking in hot air, so the thinking was that the triangles help let some air out and the scoop some cool air in The coolant temps were ok but the engine is running cooler with the added ventilation |
