Old 1st July 2010, 04:36 AM
Question Front frame again
While my chassis is tacked i have been looking at the wishbone brackets.I have noted that the ff2/ff3 uprights turn outwards on a slight angle which means i will have to pack out the front edge only to get it square with the mount located on u1/u2.Is this a normal or have i dropped a b@##@ck.
The only thing i have wondered is when making the front frame if you turned ff2/ff3 and aligned the side face with the end of ff1 instead of the front face this would position it better?
