Old 1st July 2010, 02:21 PM
Eternal Eternal is offline
right! got 24m of 25x25x2 erw box.
Have found a gearbox,dif,prop, clutch,flywheel, pressure plate, slave cyl that will fit perfect! now just got to haggle a price lol
Skyline Roadster
Old 1st July 2010, 03:27 PM
sweet! got gearbox, slave cyl,fork,diff,prop,drive shafts,flywheel, clutch,preassure plate, spigot bearing and release bearing. £400 quid collecting tomorrow so yeah will now have a full drivetrain wooooooo
Skyline Roadster
Old 1st July 2010, 08:19 PM
Finaly started! Bought a front frame from Andy way too much bother to make one myself lol should arive tomorrow.
Had to make the rear box first then did a few tacks to hold it together then moved it into its new home. Engine bay stretch causing more trouble lol
Skyline Roadster
Old 1st July 2010, 09:20 PM
comming on quickly
Old 2nd July 2010, 04:41 PM
in ref to br1-12 when it says... "when you are happy with the fit of these tubes, tack weld them together, working on one side of the chassis then the other to minimise any distortion" do they mean tack every tube on 1 side then tack ever weld on the other? as i personaly would normaly do 1 tack on 1 side then 1 on the other to keep it even. Advice welcome!
Also when should i fully weld as i need to move the chassis from the jig to do the rear end. Also i dont have the gearbox or diff yet so i cant do the tunnel enterance or exit yet (end next week)
Skyline Roadster
Old 2nd July 2010, 07:49 PM
Are the front frame uprights ment to run parallel down the length of the frame? having a bit of trouble with a complete front frame i bought. If i get the top level its way way out on the 75mm from the front measurement. and also 1mm too low. if i pull it forward on the top it goes to the right hight but the ff4 has a slope. Guess i should untack it and check to make sure its true. Damn really wanted to not have to mess around with the front frame. Also i think its slightly twisted if i get the front dead level the the top ends of f4 are slightly off by about 3mm from each other. Just check the elbows of the bends and ff3 is 3mil sticking out from the width of f4 and f2 is 1mil sticking out. Maby its me i duno what do you guys think? Good news is the frame base is all tacked now. Did a tack then did another on other side.. must have walked miles lol
Skyline Roadster
Old 3rd July 2010, 10:42 AM
Can anyone post a pic of the join between u3 and u6 i cant tell from the book how they are ment to be aligned.
Skyline Roadster
