Old 6th July 2010, 12:39 AM
Twin's Avatar
Twin Twin is offline
Default Dilemma!
Hi all,
I have a bit of a quandary with my donor. As you know I have the Sierra 2lt twinky, but I also have the option of an MX5 with a recon engine having done 40k & a gearbox that’s done 20 mile.
My question is what would you do, what would be the better build?
Thanx all
Twin
CSF £857.19
Twins Roadster
Old 6th July 2010, 12:42 AM
RAYLEE29's Avatar
RAYLEE29 RAYLEE29 is offline
ditch the twincam for sure you know it makes sense
Total spend so far £1116.08
1ST ALBUM HERE
2ND ALBUM HERE
Old 6th July 2010, 07:16 AM
Eternal Eternal is offline
mx5 all the way. Nice engine
Skyline Roadster
Old 6th July 2010, 10:01 AM
MX5, just make sure if it's an early engione that the front crank pully has been sorted as early ones worked loose and destroyed the crank nose.
Old 7th July 2010, 10:23 AM
Twin's Avatar
Good call TT,
on cold start the bottom pully wobbles slightly
I think i'll stick with the good old pinto without the ECU
Twin
CSF £857.19
Twins Roadster
Old 7th July 2010, 10:59 AM
Go with your Pinto for now Twin, it will make building / costs a lot easier and you will get a much easier IVA / emissions test. You can always upgrade afterwards, makes for a nice winter project to keep you out of trouble.
Regards....AndyH
Old 12th July 2010, 03:09 PM
Coozer's Avatar
Coozer Coozer is offline
The lighter front uprights on the Mazda would tempt me away from the Sierra.
Doesn't matter which engine as long as its a zetec really....
MNR Vortx Build Diary
www.mymnrvortx.blogspot.com/
Old 16th July 2010, 11:46 PM
Big Vern Big Vern is offline
Go with the MX-5, it was designed as sports car so you're on a winner to start with.
MX-5 engine either the 1.6 or 1.8 is bulletproof and the gearbox has better ratios than any of the stock ford boxes. If it's a jap import then could well have LSD!
Plenty of parts available.
BV
